We are getting errors with using netflix over PepVPN, Netflix is blocking it.
We are getting this message:
Whoops, something went wrong…
Streaming Error
You seem to be using an unblocker or proxy. Please turn off any of these services and try again. For more help, visit Netflix says, 'You seem to be using a VPN or proxy.' | Netflix Help Center.
The last time I looked into this Netflix was using what amounted to a large blacklist of IPs it considered to be vpn/proxy servers. You son’t say where you are hosting your hub, but I can imagine that if you were hosting it as a FusionHub on AWS for example that Netflix would likely consider all IPs from AWS as potential proxy/vpn servers and just block the whole /8 block of IPs.
I suspect that you’re going to find it a challenge to bypass their detection processes.
