I have a Max Transit Cat 18 and would like to use my Nest Wifi Router and AP as my mesh network. Can I connect the Nest Router to the Max Transit and are there any specific settings I need to change on the Transit? (I assume disabling the Transit’s AP?)
Just plug it in to the LAN and disable the AP on the Transit if it causes interference.
Should be fine.
