Hello i have some case scenario anyone that could suggest for this ? thanks
I think you are looking for the βCostβ parameter. Adjust this value so the figure is higher for the PepVPN or SpeedFusion link between B & C than the other paths. In a Balance router this parameter may be found at Network β VPN β SpeedFusion β PepVPN Profile. The tool-tip says βOSPF will determine the best route through the network using the assigned cost.β You may find further information in the firmware manual. I might add that this feature works very well and is nicely implemented.
