Can someone provide this info? Thanks!
You can order a replacement power supply directly from Peplink if you like, or would you prefer a UK based supplier of a 3rd party power supply that would work?
CPC/Farnell do a 12v 3A power supply with a 2.1mm connector that would work fine for the Balance 20/30/210/310.
Thanks for the info! Is there a specific part number to order a replacement power supply directly from Peplink (e.g. ACW-XXX)?
Can you advise which Balance unit that you have would need the power supply? Thanks.
Balance 210
Thank you for the details. The power supply for the Balance 210 should be 12V2A; product code is: ACW-601-UK.
Thank you for your assistance!
Hello, could I double check for the Balance 20, the 3 pin UK power supply would be the same part code?
Thanks, Neal
For the power supply of the Balance 20, the product code is ACW-601-UK.
