modiam
1
Hi there,
Using balance one with firmware 6.2.1.
Configured Extended DHCP Option 119 with type string and value “mydomain1.com mydomain2.com”
dhclient returns: Expecting a domain string. option domain-search ;
Is that the right way to specify it, any idea what is wrong?
Thank you.
I believe if your defining more then 1 domain you will have to use a “;” to separate them.
mydomain1.com;mydomain2.com
modiam
3
Thank you Jarid,
Your suggestion does not work, still same problem (even with single domain name).
Hi modiam,
Please try DHCP Option 119 with Type Byte and Hex value. 2 articles below are very helpful to setup DHCP Option 119.
https://blogs.blackmarble.co.uk/blogs/rhepworth/post/2012/06/18/Adding-DHCP-Option-119-(Domain-Search-List)-to-Windows-Server-2008-R2.aspx
Hope this help.
