I have a L3 SpeedFusion tunnel from site A (B580) to site B (BR1). From a device on A, is there any way to reach a device on B without defining the gateway on the device of site B?
Something like “NAT Remote Connection”?
Thank you,
Gorka
Thank you,
Gorka
Hi Gorka,
if “NAT Mode” is turned off in the PepVPN Profile, then both routers should have the Routes of each other. So it should work out of the Box.
Kind regards
Johannes
Thank you Johannes,
NAT Mode is turned off in both sides of the PepVPN profile. But if I don´t configure the device on B with the BR1’s IP as gategay, the communication doesn´t work.
Regards,
Gorka
What is the reason for not configuring a gateway on the device connected to the BR1?
You need that device to be able to send traffic across a layer 3 boundary, how else do you expect this to work without a gateway configured?
