Hi Everyone!
I need to configure NAT a MAX BR1 Mini.
Lan interface on BR1 have a 10.x.x.x address.
BR1 is also connected to a firewall that is the gateway of the private network to Internet.
What I have to do to configure this scenario?
Hi Everyone!
So long as the Mini has had the license applied that enables the WAN port, and the firewall provides DHCP, you just need to plug in a cable between the WAN of the mini and the LAN of the firewall then login and change the LAN network details from 192.168.50.0 to your 10.x.x.x address.
Hi Martin! Thank you for your reply.
I have another question, what is the purpose of providing DHCP for the firwall in this case?
Where I have to assign an address in DHCP?
Regards.
The WAN port of the BR1 Mini needs an IP address. You can either manually enter that address or if the firewall is providing DHCP you can just plug the WAN port of the BR1 mini into the firewall.
