Good afternoon! I am wanting to perform a Cisco configuration called:
ip nat inside source static and
ip nat outside source static, could you help me to know if it is possible and in what menu or tool can this configuration be done?
Ah, well it Depends on what you’re trying to do.
“ip nat inside source static” is the default configuration for LAN to WAN on a Peplink (all WANs are set to be in NAT mode with WAN IP as source when LAN devices connect to the internet).
However “ip nat outside source static” is not possible between local interfaces / subnets as Peplink routers don’t do SNAT.
Unless you are actually looking to get traffic to flow between remote VPN connected Peplink devices that have overlapping subnets in which case you can use Virtual Network Mapping. https://www.youtube.com/watch?v=C1FMdZCn3Z8
