Does anyboody know the name of the 4-pin connector used on the Max Transit Duo? I’m trying to buy one to wire the unit in since a pigtail wasn’t included but the name of the connector isn’t listed in the user guide or datasheet. It doesn’t seem to be a standard ATX connection either.
Anyone have any leads on what it’s called or where I can buy a pigtail for it?
Pepwave and Cradlepoint use the same GPIO connector and I’ve found the Cradlepoint ones cost less. They do come in different lengths, here’s an example.
Also you can just cut the transform off the cable that comes with it and use that as a 12v pigtail.
