Hi, I have been using a peplink balance 50 for quite a few years now. Today it just quit. It seemed to have frozen ( all lights on) and I removed the power supply, waited for about 30 seconds and plugged it back in and then nothing. No power or status lights. Is there anything I need to check?
Many thanks,
Raffi
Hi! Welcome to the forum.
Oh wow, I haven’t seen a B50 in ages!
Normally when you plug in and get no lights at all the first thing to check is the power supply itself. I would still try that, you may be lucky and it might just be a fault PSU.
Hi Martin,
Thanks for your feedback, I checked that and powered my peplink balance 50 with the another psu and tested the psu on another peplink balance 30. And it worked fine.
Best,
Raffi
@Raffi_Currimjee, seem like it is a RMA case. You may open a ticket to process RMA if the device still under warranty.
