Can Peplink terminate multiple VPN’s on a single head-end router/balance? I have an ISP wanting to know if they use the Balance range with multiple customers who could be utilising the same internal addressing can multiple VPN’s be terminated into on router/balance.
G.
Hi Grant! Hope you’re well. Bet I know which customer that is
Yes you can have multiple remote sites with devices on the same Subnet if you NAT the VPN connections at the head-end / hub device.
In the SpeedFusion Profile on the Hub device click the NAT Mode check box.
Hi Martin,
Long time no speak hope you are well.
Thanks for the confirmation I go back to my customer with a positive response, the ISP based in Birmingham if that’s who you are thinking about .
Regards,
Grant.
