Multiple tunnels between one device and FusionHub - VRF
Hello Support
Can a Peplink router (say a 310 in HQ) open multiple Speed Fusion tunnels to one FusionHub? On the Fusion Hub I want to isolate these tunnels each in a speperate VRF to which I will connect a branch in order to create a star toplogy with the HQ in the center, not the FusionHub
Hi Omar,
you can create one SpeedFusion Tunnels between two devices.
You can add up to 5 Subtunnels in this.
maybe this helps
