Hi
We have a case where we have 2 x Peplink devices behind a single firewall, and I’m struggling to get the port forwarding set correctly to enable PepVPN to get to the correct device.
I have the following ports forwarded
4500(UDP) + 32015(TCP) forwarded to Balance #1 - This works
4501(UDP) + 32016(TCP) forwarded to Balance #2 - This only works if I change 32015 to be forwarded to this, but then stops Balance #1
The PepVPN’s are setup with InControl2, and there is a way to change the default Data Port, but it seems not the Handshaking port, which I suspect is where this is failing.
Any ideas or do I need to have a re-think?
Mike
