Hi guys
Will there be any support for configuring each LAN ethernet port with it’s own network address? The reason I ask is there are some cases where it would be desirable if one of the LAN ethernet ports where on a different subnet or network without the need for a Layer 3 Switch or Router.
Yes it does add some complexity for users, but as a power user option it will be very advantageous. To hide this complexity, something like an “enable LAN advanced mode” checkbox. When the power user checks this box the “IP settings” field changes to four different fields e.g.
LAN Port 1 IP settings:
IP Address:
Subnet Mask:
Speed
LAN Port 2 IP settings:
IP Address:
Subnet Mask
If however only 1 of the Ports is chosen to be on a different subnet then the user can bind the remaining 3 LAN ports together with a checkbox.
