I currently have a Pepwave Max Transit (MAX-TST-GLTE-G-T-PRM) and running the lates firmware (8.1.3s003 build 5183). I am connected to a Parsec Husky Pro 7 mounted to the top of my trailer. I am interested in getting a pole most and mounting a directional antenna (Yagi or Parsec Akita - I know it’s omni, but pole mountable) and looking to use the existing antenna setup for normal use, but when I need the extra reach switching to the pole mount.
Is there something I can use to plug both antennas into something and then that goes into the router and I can use a switch? I am fairly new to all this and I was trying to research this, but searches were returning 4x4 mimo antennas.
Any suggestions or a place to dig into research would be appreciated.
John
Might be hard to find what you want off the shelf.
You need an 8 in 4 out mux, that is switchable between two groups of 4 inputs.
I am not aware of any off the shelf (at least not sensibly priced, non specialist active equipment / RF matrix devices) products, it might be worth contacting Parsec and seeing if they have any suggestions, another option would be to look at using multiple 2 in 1 out switches - messier and more things to remember to switch over but probably more likely to be able to buy something off the shelf
Hello John,
What country are you based in?
We have customised passive (not active) solutions we supply our region (Australia, New Zealand & South Pacific) that can do what you are asking for. As William mentioned, they are not cheap; they can easily cost many more times than the router.
If you are interested, send us a PM or raise an enquiry through Peplink and reference this Forum Thread.
Happy to Help,
Marcus
