Hi Guys
Model Peplink MediaFast 500
Firmware6.3.3 build 1778
I have configured multiple VLANS 192.168.10.1 / 24, 192.168.20.1 / 24
Would it be possible to configure separate DHCP for Both the VLANS ?
Regards
Hi Guys
Regards
If your question is something like below, then it is definitely supported. Else, do elaborate more on your requirement.
VLAN 10
VLAN 20
100% That is Correct
Maximum VLAN’s I can create ?
Will I be able to NAME the VLAN
Can I configure the VLAN using CLI ?
Thank you WeiMing
Hi roshan_f,
Please see the screen shot below for how to create VLANs.
Thank you roshan_f, I hope this helps.
Thank you
Appreciate your help
Hi Jeffrey
I have 3 LAN ports on the pep link 500
would like to assign 192.168.10.1 /24 to one interface 192.168.20.1 /24 and 192.168.30.1 /24 To LAN interface 3 how may I do this ?
Regards
Please upgrade to the new firmware version 7.0 and you can configure this under LAN > Port Settings.
Thanks.
