Background:
Multiple (three) AP One Mini AC access points have been deployed at one location with both radios active. In IC2 the channel selection is set to “Auto” for both radios.
The coverage of the APs overlap.
HW: 1
FW: 3.6.1 build 1889
Issue:
The 5GHz band channel selection becomes 36 for all three.
Rebooting the units does not change the selection.
IC2 “Update auto channels” does not change the selection.
FWIW: The 2.4 GHz band channel selections are nicely spread out.
Unsatisfactory work-around:
The obvious - manually set the 5 GHz channels.
Question:
Is this a bug (please fix) or some setting that I have overlooked? Is there something I can do to make the Auto channel selection work?
Thanks for reporting this and appreciate the workaround you did. We do encounter this issue and bug has been filed. Engineering team will work on the fix.
