Is there any way to forward multicast traffic between VLANs with a Balance 20, just like the way you can do Bonjour forwarding?
No there is not.
That’s very disappointing… Thank you Martin.
Best Regards,
John Calefato
JJC Communications
Main: 732-297-4500, Ext. 305
Direct: 732-412-1310
Fax: 732-412-1293
@jjccomm, seldom we see such a request for general multicast traffic forwarding, as stated by Martin. However, Peplink has implemented something similar, for Apple networking service, called “Bonjour Forwarding” that you can find in a Balance 20.
Sample screen capture from Balance 20 running latest firmware, 8.0.2 RC1.
Is this something you are after?
Hi WeiMing,
Thanks for the reply. I actually do already use Bonjour Forwarding for Apple airplay to work properly when Apple TVs are located on a different VLAN than the customers main WiFi. It’s a great feature. I use it a lot.
That’s actually what gave me the idea for the multicast forwarding. The problem I’m having now is that Sonos uses multicast for device discovery. So if the Sonos devices are on a different VLAN than the customers main WiFi, the Sonos app does not find them…
Best Regards,
John Calefato
JJC Communications
Fax: 732-412-1293
Is there a roadmap to support Multicast Routing (MCR). In Germany the VDV (vdv.de) defines standards for whole transportation industry. And the IBIS-IP network depends on Multicast Routing for service discovery.
Please implement MCR.
Documentation:
https://www.vdv.de/301-2-sdes-v2-2-common-conventions.pdfx
