Multi-Site (3) VPN Question
The company has 2 sites connected with a VPN connecting both site’s subnets. Each sire has a Peplink Balance One. This has served us well for a few years.
A third site is coming on board. The plan is to upgrade to a better model of the Peplink (a 380) to the main exiting site and move the Balance one from there to the new 3rd site. Re-configure the routers to Main Site (380) has VPNs to the other two sites (Balance Ones).
Question 1: Will this work with the products mentioned?
Question 2: Could a VPN also be established between the two Balance One sites? (so all three sites could send data directly any other site)
Thanks for your advice.
Yes this is a typical configuration, and exactly what we use. B380 as home office, and Multiple Balance One at remote offices. Would set up a VPN from each remote to home, and then also one from remote to remote. With that you have a triangle. The routers are smart enough to use the direct link when appropriate.
Depending on the amount of users and data, you might do just fine with a third Balance One.
Thank you for the reply. I can rest easier while waiting for the 380 to arrivae.
