Could you implement a multi-select to the SMS part of the Toolkit? This would enable us to check multiple messages (or Select All), and delete more than one at a time. The toolkit is quite slow when deleting messages one at a time. Thanks!
Tridens
Tridens
It would really be helpful!
Or just auto-delete the old messages…
Any improvement on this subject? I use Max Transit DUO (2 off) and:
– The SMS toolkit is really slow
– Deleting the SMS messages one by one for each SIM is REALLY boring (a volunteer developer can try this by him/herself and experience the short time interval until he/she bangs the monitor)
– I could not find an API command which would do the job (and adopt a small script?)
If there is a way, can someone provide some information to enlighten us?
Thanks in advance…
I noticed mine say s 27 of 30 available spaces under the SMS toolkit sms storage. What happens if you get to 30 of 30 without doing anything - does it auto delete as is? (or is that just for the pagination)
Hello All,
Any improvement/plan/projection/good-will/hope/hopelessness on this subject?
As of firmware 8.2.1, there is not to my knowledge/experience…
Thanks in advance for your comments.
