I’m using a multi-IMSI SIM card. How can I load available Carriers and select which one I want to be connected to?
Thanks!
Thanks!
Would it be multi-imsi or regular sims, it is the same:
Go on the details of the cellular module, go on carrier selection, click on the ? and click on “here”.
Then select manual and do a scan.
Thanks. This works!!
