Multi carrier sims
I have been told that there are carriers that resell for multiple cellular providers. They are supposed to offer multi carriere sims that detect the strongest carrier signal and failover to that carrier. Do Pepwave cellular routers supposed this sort of thing?
Yes Peplink supports them. You can also buy directly plans from them.
What are some services that offer this?
Hello…
Well… To do that… you need a device that can handle multiple APNs configurations for the same SIM CARD… Never see a device that can do this!
@MarceloBarros You can use the peplink esim and specify the plmn that you want to connect to.
We do have a variety of packages offering this in different configurations depending on your requirements (regions, volume, etc)
Actually we have devices that can do that, you can either select the APN from a list or set a round-robin configuration
how can i pick the carrier - I have an older device so using a physical sim with multi carrier (eSim) plan
currently my MAX BR1-MINI LTEA is connected to Verizon but its painfully slow - like 1-2 Mb/s
