Hello.
Can you recommend suppliers of magnetic mounting kits for the Max-S?
Also, do you have the operating specifications for said kit?
Thanks.
Hi Sergio,
Peplink has Magnet Mounts for the Antenna Max S:
- ACW-676 (6-piece magnet pack set)
- Magnet size D50 x H10.5 mm, with M6x20 thread (stainless steel)
- Magnet is coated with black rubber to prevent surface scratches
- Single magnet Shear force 29.2lbs (13.2kg), Pull force 101lbs (46kg)
Let us know if this helps ![]()
G.
Thanks Giedrius for your answer.
Could you share the volume and weight of each kit with me so I can calculate the cost of acquiring and transporting them to our facilities?
Hi Sergio,
Below is packing information I got from our internal team:
12pcs per single giftbox
Box dimension: L280XW200XH140mm
Gross weight per box: 2.079kgs
Note: since these are very strong magnets, we used a special packing so that it could be used for air shipments. Just wanted to add a note so you are aware.
G.
