More than one image
I need to link to an externally hosted image on the portal page and it is not working … if this cant be done is there any way to upload via sftp or ftp to the device flash so I can add more than one image…
GavinG
:rolleyes:
You will need to upload it via your local machine and only one image is supported so you will need to create your own image first.
