Hi Team, are there any plans to offer a license to increase the number of PePVPN’s on the MAX-HD2-LTEA-W-T?
I actually see now that MAX-HD-020-SPF is compatible with the MAX-HD2-LTEA-W-T. Can you please update the spec sheet on the website, as it reads:
“+ The HD2 Mini and HD4 come with 2 PepVPN/SpeedFusion peers by default. With an optional add-on, they support up to 20 peers.”
Thanks for figuring out this. We have already done two changes on the web page (https://www.peplink.com/products/max-cellular-router/multi-cellular/)
Model Comparison of MAX HD2 > Number of PepVPN SpeedFusion Peers
[before] 2
[after] 2/20 + -
Remarks of “+”
[before] + The HD2 Mini and HD4 come with 2 PepVPN/SpeedFusion peers by default. With an optional add-on, they support up to 20 peers.
[after] + The HD2, HD2 Mini and HD4 come with 2 PepVPN/SpeedFusion peers by default. With an optional add-on, they support up to 20 peers.
Our further follow up:
- Will double check if HD2/HD4 with MediaFast should be applied on this optional add-on too
- Will update the store to ensure all HD2 products with MAX-HD-020-SPF features add-on
Glad to be part of the team! Thank you
