Can you please add the ability to select which WAN port is notified upon a up/down.
We have false positives in that the Cellular is cycling due to the Network sending a disconnect/reconnect.
Main goal is just trying to setup an alert for when the Primary Fails.
Thank You,
Eric
+10
Incontrol improved notifications on WAN up/downs highly needed. Even filtering alerts with filtering rules in mailbox is a nightmare, especially when renaming WAN ports (ie WAN - Line number). When using data use limits from within the router mailboxes are also “spammed” with wan up/downs alerts on cellulars.
