KPS
1
Hi!
I want to use Speedfusion with MultiWAN on “both sides”.
What I miss is the ability to monitor “external” the current usage of the “transports” of the link like:
- Traffic branch-WAN-1 to HQ-WAN-2
Is there any possibility to achieve this via CLI or SNMP?
Thank you
Regards,
KPS
Hello KPS,
If I’m understanding the question correctly, you should be able to do this with SNMP.
Zach
KPS
3
Hi Zach!
Can you tell me the OID that covers that traffic? I could only find OIDs for the speeds of the physical interface, but I still need:
- Bandwidth-Usage of a PepVPN/Speedfusion-Link
- Bandwidth-Usage of every “Sub-Tunnel”
Thank you for your help!
KPS
@KPS,
You need to use Peplink SNMP MIB files to monitor the usage. You can download the MIB files using the following URL:
http://download.peplink.com/manual/peplink_balance_snmp_mib-6.3.zip
If you open the MIB file using MIB browser, you should see the followings:
