A question about eSIM and data volume. Is there a way to monitor the data volume used by an eSIM?
It would be perfect, for example, to receive information via Pushover when a certain volume has been used.
Or is there an eSIM provider that offers this service throughout Europe?
Thanks a lot for your help!
Are you able to use InControl2 with your Peplinks?
If so you can certainly create a SIM pool (even if it only has one member) and set it to alert at a specific utilisation threshold.
Depends what you are looking for, most of the “proper” providers that supply multi-net SIMs and similar have very comprehensive monitoring and alerting available.
