Hi everyone !
I want to monitor performance (CPU,RAM …) of Peplink Balance 580 use SNMP.
Device’s peplink have Firmware 5.4.7 build 2423. I was downloaded MIB file, but all don’t have info CPU, RAM …
So, Can you help to dowload MIB file for Firmware 5.4.7 then can monitor performance’s device ?
Thanks .
Please upgrade B580 to v6.2.1RC. Our CPU and RAM can be monitor by standard MIB which should be available in most of the monitoring software.
Thanks TK Liew.
I using opManager software monitoring Peplink device. But, in opManager haven’t vendor of Peplink be I need to create a template for Peplink device with MIB file.
As you reply for me, if my B580 use FW 5.4.7 that will don’t monitoring performance (CPU,RAM …) by MIB file ?
Regards .
Correct,
B580 will need to be on 6.2.1. We have made many improvements/advancements regarding SNMP since 5.4.7. If you have the latest MIB and 6.2.1 firmware, you should be able to monitor CPU/RAM on opManager.
So, If don’t upgrade B580 to 6.2.1 and use FW 5.47. Can i using MIB file to monitor (CPU/RAM) ?
Thanks.
Yes, your correct.
Thanks !
I will recommend for custemor.
Best regards .
Sorry, so this. Can you share link for me download MIB file ?
Thanks .
You may obtain the latest MIB from the following link:
Thanks Jarid Petermann !
I was downloaded Peplink Balance SNMP Private MIB for 4.x / 5.x .
But, when i deploy that in folder download haven’t any file have OID are info CPU, RAM …
So, Can you share for me file MIB have OID display info CPU, RAM of Peplink Balance ?
Best regards .
Hi Hong Chuong ,
As mention by TK in the early post, you need to upgrade to firmware v6.2.1GA in-order to support some of the common standard MIB OID.
Memory
HOST-RESOURCES-MIB
- hrMemorySize - .1.3.6.1.2.1.25.2.2
- hrStorageTable - .1.3.6.1.2.1.25.2.3
CPU
UCD-SNMP-MIB
System Stat .1.3.6.1.4.1.2021.11
Thank You
Thanks sitloongs
So, Can you share for me link download the folder have HOST-RESOURCES-MIB and UCD-SNMP-MIB ] ?
Best regards.
Hi Hong Chuong,
The mention MIB are Open Standard MIB files.
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=HOST-RESOURCES-MIB
http://www.net-snmp.org/docs/mibs/UCD-SNMP-MIB.txt
Thank You
Thanks sitloongs.
Thanks support team
Best regards !
