May I know, if buy a new mini br hw3,I must order a feature pack to active the lan to wan port? otherwise the wan port only use as lan port?
thank
thank
You have two options.
#1
When a device is purchased the wan port is now pre-activated with the 30 day trial license.
Then when connected to the internet and it verifies it’s primecare license, with primecare , you will have the wan unlocked for 1 year.
You could then continue to renew primecare to keep the wan activated.
#2
You could buy the feature pack and it will permanently unlock the feature.
They also have a bundle where you buy two or four additional years of primecare and get a feature pack.
As a peplink partner let us know if you want us to order one for you.
