I am looking for help and/or suggestions.
I have a BR1-Mini that is using a T-mobile hotspot SIM 100G / month and overall works great, zero issues in my Airstream travel trailer.
I have Blink cameras that I can monitor the cabin and it fully operates the video and controls of the Blink cameras anywhere, I mention this because it shows it works as intended.
My issue is I installed a Micro-Air Easytouch Thermostat:
It works via Bluetooth and Wi-Fi. The issue I’m having is “unique” because in Bluetooth range, it works exactly as intended. The touch screen shows a GREEN icon showing internet is connected. There is a sun and moon icon, when pressed, returns a clip of the current weather at its location. This tells me the coms are good and it can retrieve data via the BR1-mini.
What is not working is the phones app via the Wi-Fi outside the Bluetooth range but from what I’m told should work exactly as the Blink cameras do. I’ve been in touch with their support (micro-air) and that is still ongoing.
I was sent to this page:
At first I had a red Icon on the wifi, but that resolved over the last 5 days I’ve used it and like I said, it was getting proper weather updates.
The article refers to MQTT and port 8333. I “suspect” that this may be the problem, but I’m unsure if that really is it. Since the blinks work without issue, I would expect the tstat to work the same as both are considered IoT devices yes???
I’m just wondering if anyone had any suggestions on what I should be looking at in the admin area to “allow” which I’m assuming the router may be blocking these message types if at all?
Can someone give me a starting point to look at? I thought this would be a simple plug and pray…clearly it isn’t. I’d really like to get this working if there is something subtle that I may have missed.
Appreciate any help.
Chris
