Multiple clients have requested both mechanical drawings and CAD files containing the physical measurements of Max devices such as the Mini and the BR1 MK2. The Max products are frequently integrated into other enclosures and having this information is of critical importance. Where can I obtain this information?
Hey Len, I can’t upload a zip file here so I will email it to you. Thanks
This is great to see we can obtain the info. Is there any way we can make this public?
Hey Jon, we will work on getting all of these added to the Partner Pavilion. Thanks
Any idea when this might be available?
This is still being worked on but in the meantime just send an email to supportatpeplinkdotcom and we will get you what you need. Thanks
Tom, I tried to upload the zip of the Mini cad file but it’s not an authorized file format. If you need it send me a real email address. BTW, the cad files are stop’s so you need Autodesk or an equivalent to access them.
Mechanical Drawings of MAX devices are now available for Partner to download from here.
More models to be added.
I tried to follow the link in your message but access was denied - “Sorry - you don’t have access to that topic!”
Hi Len, we will get you added to the Partner Forum thread. Thanks
Hi Tim, I don’t seem to have access yet.
Hi Len, could you try logging out and back in again? Thanks
Hi Tim,
I logged out and logged back in - no change. I still can’t get access by following Alice Cheng’s message link “here”.
It’s under Partner Forum > Partner FAQ > Mechanical, 3D Drawings.
https://forum.peplink.com/t/mechanical-3d-drawings/16944
Hi @Alice_Cheng
Both links work now!
Hi, how can i download the max br1 mini board layout for a custom enclosure?
The mechanical is 3D so you can get the dimensions of the board and all connectors from it. Do you have the file?
Attached is a zip of the .stp file.
(Attachment MAX-BR1-mini_20161214.zip is missing)
Hi
It says the file is missing. Also no i dont have it. Can you post again please.
