MBX-F0B1 - Hard Wired devices cant see wifi devices and Vice Versa
Not sure where to begin - but basically my hard wired devices cant ping the wifi devices and the wifi devices cant see the hard wired devices. They are all in the same IP range and have the same subnet mask.
Basically just connected the new APs and let the MBX controller do the config.My Ipads cant see my Crestron AV system.
Where should I look for issues ?
Do you have client isolation turned on on your wifi?
Thanks for the reply. I figured it out. By default -it appears that the Wifi is treated as a guest network. I turned that off and it started working fine.
