May i know Max BR1 mac filter is that have limitation? is that i can put unlimited mac in the device?
Nothing can ever be unlimited friend.
I suspect you’ll find its one of the magic numbers (ie 256,512 or 1024 entries) that are max supported.
How many do you need?
Hi Martin,
thank for your replies, that the magic numbers (ie 256,512 or 1024 entries) i wanted to know. Actually customer is asking about this question and i check on datasheet, there is no answer. let said is over 200 mac address need to be input, it is able to support?
lets ask @TK_Liew and @sitloongs they’ll be able to find out for us
May i know your device actual model & firmware version ?
the model is MAX-BR1-LTE-E-T, firmware version is 7.1.2.
I just do a quick test (BR1 Firmware 7.1.2) on this with 300 MAC addresses and i have no problem to apply the settings.
Again, this may not be a good use case for the deployment as managing the MAC address list is not easy and cause extra load for the device. RADIUS MAC Authentication is recommenced for such requirements.
Ok, understand, thank you.
