I am setting up a new Pepwave MAX Transit (MAX-TST-GLTE-G-T-PRM) router. When I plug in the two SIM cards, it always shows “Obtaining IP Addresses…”
My SIM cards are:
Verizon SIM from Tablet on Unlimited Plan,
OR Verizon SIM from Jetpack 8800L from same Unlimited Plan. Both are being swapped in for testing purposes on the Pepwave. Operator Settings is ‘Auto’. These SIMs have been activated and work on other devices.
AT&T Prepaid, Operator settings is ‘Auto’. SIM purchased for this Pepwave. AT&T confirms SIM is activated and provisioned correctly, however their network has not picked up the signal or the device.
All SIM cards are detected by the dashboard. In every scenario all LEDs are: Status - Solid, WiFi - flashing(fast), Cellular - flashing(slow).
I have tried each SIM card individually or separately (via dashboard settings), resetting the router to factory settings and setting APN to ‘vzinternet’ (Verizon) & ‘broadband’ (AT&T). All to no avail. “Obtaining IP Addresses…” persists.
APN is set to vzwinternet which appears to be correct. Again, it works fine in my MiFi hotspot device. Any way to view log to see what might be happening?
Having exactly the same problem in Denmark. I have narrowed it down by changing LTE/3G to LTE, then band selection to custom, uncheck all the bands and tried one by one the bands of the SIM card provider.
I figured out that for some reasons and from the very same location. I could connect i.e. to band 7 but not to band 3 (where the sender was near and strong).
