hello,
The status light of my Transit is stuck on solid red. It worked seamlessly yesterday, and when I tried to use it later on, this issue occurred. Are there any troubleshooting tactics I can do to get this running ASAP?
kindly,
Logan
hello,
kindly,
Logan
Its rare to see that.
On a transit the first thing to do is check the power source. Dodgy power (lack of current) can cause a failed boot.
Then if fixing power doesn’t resolve it get a peperclip and push and hold in the hardware reset button for a 15 count.
Martin,
thank you for your swift help. It seems to have been the specific power source. I moved the device to a different circuit, and it’s up and running.
kindly,
Logan
Glad it was power - when it is its typically USB power sources that can’t provide enough AMPs.
Well done.
