I’m trying to get a verizon sim to connect using a Max Transit Pro. ATT & TMO seem to be working fine, but no luck yet with VZN. I took the SIM out of a Max Transit DUO so I know it is activated.
I’ve tried both modems same results. Also tried setting the network mode to “Auto” and “Verizon”. APN is detected as vzwinternet.
Is this the dual cat-12 global version?
I’m having same issue if so.
Been working with Verizon for a few weeks on this.
The IMEI numbers of the Quectel EM12-G CAT12 cards have not been registered with Verizon’s Device Management Database so the network won’t let them on in our case.
I my experience the issue is far more likely to be one with Verizon than Peplink. However, in this case I’d submit a ticket and let Peplink address the issue.
USA cellular carriers – generating frustration for users every day …
This was user error. I have to use a different APN from what is auto detected. TRACFONE.VZWENTP is the value I use. Not really sure why, but that is the case.
