I’m curious if anyone can recommend any videos for learning the basics of the Peplink Max Transit Pro and speed fusion cloud setup. I have a unit setup, but I just want to make sure everything is correct and its setup properly.
Let me suggest that Youtube is a good place to begin. I think the first one to come out was this good one by @Travis. Several Partners made additional ones thereafter.
I am not aware of any videos vis-a-vis your specific router but I will mention that “Outbound Policy” is your friend in making SFC work effectively and getting the traffic into the right “pipe.” It’s a very powerful tool which is easy to use. Your Peplink Partner should be of value in getting you going and there are many folks here in the Forum who can help.
