Max Transit Duo Local Bonding
Hello, all!
I have a Max Transit Duo, which has two separate modems with two SIMs each. Everything I’ve been reading discusses bonding between multiple Pepwave devices. However, is it possible to bond these two modems together, without using Speedfusion Cloud or an off-site server (i.e. VULTR)? Does that makes sense? Thank you!
No its not possible to use bonding without sending your traffic via another device or server/service.
However you can use both connections at the same time and load balance your traffic across both links.
