Pepwave Max Transit Duo, Firmware 8.1.3 build 5172
Poynting 7-in-1 antenna on the roof
iPhone 13, iOS16.6, carrier is Visible. This is our plan C back-up plan (unlimited data) in addition to 2 SIM cards (AT&T & T-Mobile) already in the pepwave, and also my wife’s phone.
When I try to use the “personal hotspot” with default settings on the iPhone, I can connect my PC or my Amazon fire stick without any issues, but not the Pepwave’s wifi as wan.
I tried to rename the iPhone with lowercase non special characters / no space only: no changes.
I then tried to use the “maximize compatibility” feature on the iPhone, which basically uses 2.4GHz instead of 5GHz and it worked.
Any idea why?
Any chance I could make it work with the 5GHz, since the phone is 6 feet under the roof antenna?
Seb
