I have a max transit duo with AT&T sim as wan, Tmobile hotspot as wan (via wifi) and starlink via ethernet. Starlink puts out its own wifi which appears to be the same lan as the ethernet port. My computers are mostly all on wifi lan.
All this works, except - If I connect to the starlink wifi (which in theory is the same lan as ethernet) I can’t communicate with the Max wifi-lan.
I also have the management setting in the starlink ethernet, but I can’t access starlink router web from the max wifi-lan - I have to connect to starlinks wifi in order to connect.
Is there a simple way around this?
tnx
mgg
