Hi guys, I just want to know, is there any big difference between Max Single Cellular and Max Multi-Cellular. Maybe in terms of their performance, features, or workflow?.
Hi - welcome to the forum.
I’d suggest you look at the comparison pages to see the differences between models.
https://www.peplink.com/products/max-cellular-router/single-cellular/ and
https://www.peplink.com/products/max-cellular-router/multi-cellular/
Fundamentally the differences are typically number and type of physical ports (LAN WAN and wifi), some have serial interfaces, some have removable cellular modules for future upgrades.
So when selecting a MAX start with the interfaces you need, then check throughput / category of modem you want to use then consider form factor and you’ll have the right product in mind. Or speak to your Peplink partner who does this everyday and get them to help you choose.
