I just discovered your product, and i think that’s just what i need, i am planning to use it for streaming video.
I
i just need to send max 2mb aprox, and i would like to know if i need to have another MAX-OTG-U4 at the studio, i am going to use the load balance and failover features only.
I am going to use the Speedfusion feature of the MAX-OTG-U4-SF on the field, what unit do i need to buy for the studio to receive the bonding on the vpn, and pass to a video decoder via lan?
I have enough internet at the studio (50MB dl) the VPN will come in using that wan connection?
Yesterday i get my new MAX-OTG-U4, and works as expected, now i would like to know if there is a trial license to test the unit with speedfusion, i already installed the fusionhub trial, and i would like to test the bonding feature to see if we upgrade to the next level.
Hi elduran I am exploring the use of a MAX OTG U4 for the same purposes as you. Are you using yours over multiple bonded 4G devices? Have you experienced increased speeds over just using one of your 4G devices?
