What is the max MTU size that is supported on Peplink SOHO, Balance, and Max series routers?
We follow the standard. Please refer below:
These are our default WAN MTU.
- Wired WAN - 1440 bytes
- Cellular WAN - 1428 bytes
- Mobile Internet - 1492 bytes
- Wifi WAN - 1500 bytes
Thanks for the reply.
So assuming the network that the peplink router is connected to supports Jumbo Frames. Can the peplink router support Jumbo Frames.
