Does anyone have experience with MRTG and Pepwave, specifically a MAX HD4? I’m running 6.3.3 build 2526. I have SNMP v1 enabled on the HD4. When I poll the HD4 with CFGMAKER, it only shows one active LAN interface, and two disabled WAN interfaces. I do have an active AT&T WAN port, so not sure what CFGMAKER is seeing. Also, why only one LAN port. Is it some sort of aggregate bridged port? Can you not discreetly poll each individual switch port? Here’s what CFGMAKER is returning. Any tips/thoughts appreciated. Thanks.
Created by
cfgmaker [email protected]
Global Config Options
for UNIX
WorkDir: /home/http/mrtg
or for NT
WorkDir: c:\mrtgdata
Global Defaults
to get bits instead of bytes and graphs growing to the right
Options[_]: growright, bits
EnableIPv6: no
System: test-pep
Description: Pepwave MAX Series
Contact: not specified
Interface 1 >> Descr: ‘LAN’ | Name: ‘LAN’ | Ip: ‘No Ip’ | Eth: ‘00-1a-dd-ee-53-00’
Target[192.168.200.129_1]: 1:[email protected]:
SetEnv[192.168.200.129_1]: MRTG_INT_IP=“No Ip” MRTG_INT_DESCR=“LAN”
MaxBytes[192.168.200.129_1]: 125000000
Title[192.168.200.129_1]: Traffic Analysis for 1 – test-pep
PageTop[192.168.200.129_1]:
System: | test-pep in Pepwave |
Maintainer: | not specified |
Description: | LAN |
ifType: | ethernetCsmacd (6) |
ifName: | LAN |
Max Speed: | 125.0 MBytes/s |
Ip: | No Ip (No DNS name) |
Interface 2 >> Descr: ‘WAN-1’ | Name: ‘WAN 1’ | Ip: ‘No Ip’ | Eth: ‘00-1a-dd-ee-53-01’
The following interface is commented out because:
* it is operationally DOWN
Target[192.168.200.129_2]: 2:[email protected]:
SetEnv[192.168.200.129_2]: MRTG_INT_IP=“No Ip” MRTG_INT_DESCR=“WAN-1”
MaxBytes[192.168.200.129_2]: 1250000
Title[192.168.200.129_2]: Traffic Analysis for 2 – test-pep
PageTop[192.168.200.129_2]:
Description: | WAN-1 |
ifName: | WAN 1 |
Max Speed: | 1250.0 kBytes/s |
Interface 3 >> Descr: ‘WAN-2’ | Name: ‘WAN 2’ | Ip: ‘No Ip’ | Eth: ‘00-1a-dd-ee-53-02’
Target[192.168.200.129_3]: 3:[email protected]:
SetEnv[192.168.200.129_3]: MRTG_INT_IP=“No Ip” MRTG_INT_DESCR=“WAN-2”
MaxBytes[192.168.200.129_3]: 1250000
Title[192.168.200.129_3]: Traffic Analysis for 3 – test-pep
PageTop[192.168.200.129_3]:
Description: | WAN-2 |
ifName: | WAN 2 |
