Hi to everyone,
I need to reach a CCTV with link-local ip address (169.254.0.185).
The CCTV system is it not of my competences, is it impossible to change IP address
I have a HD2 router with my devices connected in LAN1 and internet in WAN1.
I connected the system of CCTV in WAN1 but I can’t reach the CCTV.
If I try to change the IP of 1 camera with another IP (like 192.168.50.185) it works correctly.
I have the following network configuration:
CCTV
- 169.254.0.185
SWITCH PoE
HD2
- WAN 1 - DHCP ON
- WAN 2 - Static IP - 169.254.0.100 - DHCP OFF (connected to PoE SwitchI )
- LAN 1 - 192.168.33.1 - DHCP on
Oubound Policy
- CCTV
- Source 192.168.33.0
- Destination 169.254.0.0
- Algorithm Enforced
- Enforced Connection WAN: WAN 2
- CCTV
It is possible to ping camera from WAN 2.
When I try to ping camera from PC (connected in LAN1) I
I noticed that it’s the pc itself that replies negatively to the ping.
Ping does not reach the HD2 device.
I think because 169.254.xx.xx it is a special link-local network, PC doesn’t try to reach it.
Is it possible to reach the link-local network of CCTV?
Do I have to setting special routing roule?
Thank you so much to everyone
