MAX HD1 Dome Pro looks good because it has WiFi WAN and 5g capability. It would eliminate the need for external antennas, mounting them, running wires which will lead to signal loss & additional work. Separating the LAN AP to a Peplink AP One AX/AX Lite and also having Starlink, how would I wire/configure since the HD1 Dome Pro only has one ethernet and I would need two one for WAN and one for LAN? The starlink will not use Starlink router and I want it to show as its own WAN that I can drag & drop from priority (active) to disabled on the Dashboard. Can the MAX HD1 Dome Pro also manage the LAN AP (change setting to External AP from Integrated AP under AP Management)? Does the HD1 Dome Pro support Speedfusion smoothing?
please help
Hi Bob, did you ever get a solution for this question? I have the same requirement
We (1SimpleConnect) are a Authorized Peplink & Starlink Solution Provider and can help you set this up.
Do you already have a HD1 Dome Pro , or do you need to purchase one?
For this solution we would also need to add a PSW-8-240W-RUG switch and LIC-VWAN license.
We can help you setup the vlans, vwans so that you can do the solution with 1 cable.
PM me or contact me for details and we can help. [email protected]
