I’m planning an install on my sailboat with the Max HD 1 Dome. I’d like to be able to use the Wifi-as-WAN feature to connect to the marina wifi, as well as run a local wifi network for devices on the boat to connect to.
What would be the ideal product to tie the Max HD 1 Dome and SIM injector together? Would the Surf SOHO work? What would the network look like? Would the HD 1 Dome plug into the WAN on the Soho Surf, and then the SIM injector plug into the LAN?
I have been reading through the forums quite a bit, but haven’t found anything that addresses this exactly. I also haven’t been able to find a basic diagram for using an HD Dome + SIM Injector + ??? to create an network with both internal WiFi AP and WiFi as WAN. I know its probably a very simple answer, but I just can’t seem to find it. The closest I can find is a this thread, and it is a product idea: HD1 Dome + SIM injector + Marine Feedback - #9 by stevemitchell
When you say you want a dedicated WiFi WAN antenna, do you have something specific in mind? I found the APs already, that seems straightforward. Also, I am trying to keep the system simple and avoid having 5+ devices to accomplish what can be done with a single MAX Transit.
The other thread I started was about antennas, so I didn’t want to confuse it with this different topic.
I would us a omnidirectional antenna, not a directional! With a directional antenna you have to adjust it everytime. Only a 360° antenna is recommended for a moving device.
Can we please focus on the thread here. I’m looking for the simplest way to achieve Wifi as WAN with a MAX HD 1 Dome - it already has all the antennas built into it.
