BUG REPORT - Firmware 6.2.0 & FW 6.1.3
MAX BR1 U.S. model
re: #743528
Once again I am noticing that the FRONT PANEL WIFI INDICATOR IS NOT FUNCTIONING WITH
REGARD TO DATA FLOW THRU THE WIFI AP!! I do not use the WIFI Wan and have it disabled
at all times. I NEED this indicator to function properly with the AP giving a representation of data
flow/speed thru the WIFI AP similar to the functionality of FW 6.1.2 on Verizon model. Is there
a way to accomplish this via a admin panel tweak in FW 6.2.0 or 6.1.3??? I Looked but didn’t see
anything.
FW 6.1.3 exhibits the same non-functional data flow indication as FW 6.2.0. Simply blinking on and
off at a slow steady rate indifferent to actual data speed/flow is not sufficient indication.
