Hello everyone. Just got a MAX BR1 Slim in for a project where we need 2 LAN ports. I have upgrade the router to 6.3.1 and when I configure the WAN as a LAN it doesn’t stick. I do have the router managed by incontrol so I don’t know if that is overwriting the settings in the web GUI.
Network>Port Settings>Click here to configure Ethernet WAN ports> Enable> Save> Apply
I then get kicked back to the dashboard page and the WAN is still a WAN port.
I just tried it with a unit on my desk and it sticks every time. After I hit apply I am redirected back to the dashboard and the Eth WAN port is gone. I also physically confirmed that the WAN port was indeed acting as a LAN port.
You could try to temporarily disable router management via IC2, otherwise please make sure your power source is able to provide 2A of current. Thanks.
So I factory defaulted the router then went in and configured the WAN port as a LAN port. Looks like the settings stuck. I then went in and turned on Incontrol management and a couple of minutes later the LAN port was back to a LAN port.
Is Incontrol supposed to control this feature? If so do you know where I can disable it from Incontrol?
Can you further check whether Bulk Configurator setting for the IC2 (Group Level settings) is enabled ? This will overwrite the device configuration if default configuration is uploaded.
For more information, please refer to the attached screenshot.
